Corrupted Fieldserver model:FSX30
gmn
Sep 2011
phil
Hi Guys! Need Help.
Is there anyone familiar with fieldserver model:fsx30???
I am having a communication problem with the unit after cancelling the download process.
Normally download only took about seconds, but during the moment before the problem occurred, its about 3-4 min had passed but still downloading, so I decided to cancel the download and close the "Remote User Interface" or RUI application. I started the RUI again and established connection with the fieldserver but, communication started to failed. I tried to ping the IP address and reset the power of the fieldserver but still no reply from the device.
The unit's LED Functions indicates the ff:
"Power"=steady green light; "Run"=flash green per sec.; "Config Err"=amber light;"N2"=steady&flashing green light; "Lanworks"=flashing green
To anyone familiar with the device:
Do you think the unit is damaged or corrupted??
Did you encountered the same problem before?? What will you suggest to solve this problem??
Thanks a lot!!
I would certainly contact the manufacturer - I have found them to be extremely helpful in the past.
Hi all, This is not a call to arms. I am submitting this solution for those who find this thread because they experience the same issue. I...
652
After shipping a machine to the customer on power up some of the hmi fields are corrupted most are ok,comms ok
676
So it seems that if you upgrade convert a 5570 project to a 5370 project and update the firmware target of the project from 30 to 32 that it...
962
Hello all, I've been working on a project with an AB Micro820 for a few days. Just got the program finished and set up with the PLC, but was...
63
61,103
I have a panel view plus that boots up with 40 EXE error (missing OP or corrupted) Is there a source where I can re installed the OP? If so, can i...
1,191
