Count on Time
mcmenomy8
Dec 2017
Georgia
I'm a beginner using GX Works 3
I need to count the on/run time of a device in seconds, minutes and hours. How would I program this using ladder logic?
Look forward to some good suggestions.
you can use clock bits, if you use FX5U then 1s clock bit is SM412. Use counter function to increase DInt type of tag (seconds) with SM412.
You can get minutes and hours by dividing that number by 60 and 3600 (using integer division).
I'm using the Q-Series, will this still work? I don't think I'm using the FX5U. I'm pretty new to this. I'm a little confused by the sm412 in the Counter. How does that look set up?
If you use Q-series, then you use GX Works2. There's always clock bits in any processor.
For Q series it's M8013.
https://imgur.com/AaY5iyv
Instead "Command" use M8013. It will activate every 1s and will increase Tag in DInt format every second, making it second counter.
What is the raw count of Allen Bradley Flex Analog Output Module 5094-OF8 raw count?
130
I am working on a Markem X40 printer which uses NGPCL Commands and needs to send commands using a .net program. I need help with the following...
147
Hi, I'm programming in RSLogix 500, and I'm wondering how I would program a Jog command that does not increase the encoder count. Basically we'd...
307
Hi all, I am currently working on a software in Automation Studio that is supposed to detect when effort is inputted by a user. This is done via...
600
Hi i have project on micrologix 1400 to display cycle time count on HMI. I am beginner. in project i have six input once all input get high it...
811
