counting production
zakir
Jun 2010
dhaka
24
hello everybody
i need to do a ladder diagram for counting total number of production for all day. i was trying to with a one-shot function and addition function and counter. but i can't make it properly.
so if anyone can help me how to do the ladder diagram, i will be glad. and also i need to display the total number of products. which display i should use? im very new in automation world.
i am using omron cx-program.
thanks again
Add a rung with your condition and add an output instruction "@++D100"
This will give you an increment on one in the address D100 whenever your rung go from false to true.
You didn't mentioned what plc, the above rung is valid for CJ/CS series plc
i am using CJ1M . thanks for that. let me try and come back.
can you tell me which display i can use for this
I would use a NS series Display, have been a preferred one recently, but you have many choices of brands, models, it all depend on your budget, comm and other preferences.
budget is not a problem. but i dont want use touch screen. any normal digital display which showing only the total number and with a reset button thats fine by me.
If you don't already have a display then adding one for only this function would be more than it is worth. Add an external counter. Tie it to an appropriate signal that only happens once per cycle.
The CUB5 is an example. There may be more appropriate ones more available to your location.
I agree with Bernie there are plenty of digital counters that can count running hours using a PLC and HMI for this is overkill
But with a PLC and HMI he could do things like graph daily production, show down time, show expected and actual machine production, alert operators and supervisors when a machine is running below expected rates, show production trends over the course of multiple days, etc.
It's a very handy thing to do in production, everyone seems to enjoy it (except a few operators who felt that the machine was tattling on them.)
True enough but his post only indicated a need for daily running hours. In which case there are far cheaper solutions than a PLC and HMI.
Further detail from the poster would be helpful.
thank you all for your advises. i should tell you, this counting thing is a part of a program. and my director wants everything run by plc . he just bought the factory. all the machines are relay logic system. so i am changing and upgrading everything to plc.
so i am going to look for digital counter display.
and what tharon wrote , thats my next project for the indifferent factory.
thank you all
Hello I am looking for tips on how to count the duration of a given function and then how to display it on the hmi panel in the hh:mm:ss format...
1,700
Guys, I know it will be silly but can't get my head around it. I have 3 conveyors, every one on a separate servo drive, and 2...
25
3,499
The 1734-IB8 has no hardware counting function correct? I am trying to find something to substitute in for a 5069-IB16F (since lead times are...
1,414
Been scratching my head at what I thought should be a relatively simple task. I need to count how many rows a .csv file has, so I can later read...
2,540
Hi All, I need to count my Contactor switching times. There are lots of them so I created a template logic with local variables in FC2000. Now I...
2,119
