Siemens WinCC - Counting rows of a .csv file
Rob...
Jul 2016
Manchester
483
Been scratching my head at what I thought should be a relatively simple task.
I need to count how many rows a .csv file has, so I can later read data from the last row.
I have everything working, bar that. This is the VBS code I have so far to count the rows:
Code:
  Set fso = CreateObject("Scripting.FileSystemObject")
  fc = fso.OpenTextFile((Source),1,1).ReadAll
  RowArray = Split(fc,vbCrLf)
  NumberOfRows = CInt((UBound(RowArray)))
  	If NumberOfRows = 0 Then
		NumberOfRows = 1
	End If
  fso.close
Now this actually works, and produces the value I need. However, it throws Error 438 :- Object doesn't support this property or method.
Anyone see where I'm going wrong, or have a better solution?
Next will be to write it to also work with WinCE, but i'll cross that hurdle later.
Does the FileSystemObject have a .close method? Maybe it did in 2004 or later, but currently I think it does not (cf. this link)? If it does, it would start with an uppercase C.
I think [Set fso = Nothing] is what you want instead of fso.close.
That was it.... set to nothing.
I'd actually already written this in my function to read the csv... too long looing at the screen I think.
Code:
		NumberOfRows = 1
	End If
  	Set fso = Nothing
I would add on beginning and end.
Dim fso
Dim fc
Dim RowArray
Dim NumberOfRows
'Error handling
On Error Resume Next
fc = fso_OpenTextFile((Source),1,1).ReadAll
NumberOfRows = 1
End If
Set fso = Nothing
'close file for next read / write
fc.Close
@Lare this is part of a larger function. It's on an snip of what I was having trouble with.
FYI anyone interested, this albeit janky method works in WinCE.
Code:
Set fso = CreateObject("FileCtl.File")
	fso.Open Source, 1
	While fso.EOF = False
		Data=fso.LineInputString
		NumberOfRows = NumberOfRows + 1
	Wend
	Set fso = Nothing
Code:
    fso.Open Source, 1
    Wend
    Set fso = Nothing
(y). Some years ago I had problems for writing to same text file as it was not closed after first opening and writing. fc.close worked for that vbs coding.
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
305
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,558
Hi, I have a HMI which is a KTP1200 Basic. Let's suppose USER03 is logged in. How do I create a simple "Lock Screen" that appears if the screen...
677
Hi, At the moment, If the user fails to provide a valid username/password, the image attached appears "Invalid password or user name. Logon has...
1,577
Hello guys, Im using a siemens with WINCC in a computer and need to import to tag´s data fom a specific row in a SCV file, i have a working...
1,692
