cp342-5 and modular slaves
ungaro
May 2005
Lokeren
72
i want to connect and disconnect an ET200S station as a modular slave to a cp342-5.
When i do this through the integrated DP-port from a 315-2DP i use SFC12 to activate or deactivate a slave but with a cp342-5 this is not possible. So when i disconnect the ET200S from the cp342-5 then i get busfault. Is there a way to deactivate a slave through the software?
found out how to do it. I used FC4 DP_CTRL from the s7 library to send a command to the CP342-5 to start/stop the slave, in this case a ET200S. Use job 9 and 10 to activate.deactivate the slave. Further info in help from Step 7
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,887
Hi Ali, I'm setting up comms between DeltaV as master and S7300 cpu315-2 as slave. I have already comms using 1 cp342-5 bet this not...
2,431
Dear All, I try connect CP342-4 to remote ı/o Conection look like ok. But i cant find I/O address. you can find my configuration on picture...
2,523
I want to configure s7314ifm plc with cp module cp342-5. And after that I have to communicate cp342-5 with a vfd through profibus dp cb15. I don't...
2,377
Hello All, Just want to pick your brains a minute as mine is now dead :) I have a Siemens 315 PLC and I have a ABB drive (ACQ810) on Profibus...
5,233
