Cp342-5 with communicate with remote I/O
necyil
Nov 2004
Turkey
102
Dear All,
I try connect CP342-4 to remote ı/o
Conection look like ok. But i cant find I/O address.
you can find my configuration on picture.
Many thnak for all help
fot that config. what is input adresses?
best regards
Address Your DI from 0.
Create a DB consisting of Array[0.63] of byte, point the address to DP_RECV as for example DB100.DBX0.0 BYTE 64.
You'll find Your Inputs there.
many thanks for your answere..may you send me a DB with array?
i have anotheer im153 conneted 8X32 module DQ
Dear Adfox,
I will add 6 IM153-1 to Cp342-5. All D I/O.
For every IM153-1 Send and recive function? or just one send/recive function for all IM?
many many thanks for your answers
best regards
cp342-5
Dear Adfox,
Mant thanks for you help
I was try but cant see when input.
You can see some picture on attached.
On my hwconfig. alos added 1 cp343-1 Lean. Possible use both cp with cpu317?
Need your idea about what is my mistake
best regards
nec
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,810
Hi Ali, I'm setting up comms between DeltaV as master and S7300 cpu315-2 as slave. I have already comms using 1 cp342-5 bet this not...
2,420
I want to configure s7314ifm plc with cp module cp342-5. And after that I have to communicate cp342-5 with a vfd through profibus dp cb15. I don't...
2,366
Hello All, Just want to pick your brains a minute as mine is now dead :) I have a Siemens 315 PLC and I have a ABB drive (ACQ810) on Profibus...
5,222
Hi, i want to connect and disconnect an ET200S station as a modular slave to a cp342-5. When i do this through the integrated DP-port from a...
2,174
