CP342-5 Diagnostic
Werner
Apr 2005
IJsselstein
336
Hi there!
Normally I use FB 125 from Siemens to diagnose the profibus network. In this case I have a configuration where the DP Slaves are connected on an CP342-5 module.
I got this module working with the FC 1/FC 2 (DP SEND/DP RECEIVE) functions from the Simatic NET library. Now I want to get the same kind of diagnostic information I am used to get from the FB 125.
I the hardware configuration of the CP there is a button "Run diagnostic application" (don't know the exact words because I am not at my laptop at the moment).
This application provides lots of usefull information. (Connected stations, problems, etc) I want to be able to use this information for my HMI. According to the manual I have to use FC 3 (DP DIAG) when bit 1 or 2 of DPSTATUS from FC 2 is on.
So now I'am trying to find my way there. Anybody used this function before?
There is an example on the Siemens site but I don't have Siemens credits to buy it. (Can anybody share my a copy?)
Other tips/pointers on how to do this?
Werner
FB125 works with both integral and external DP interfaces, so it should work with the CP342-5. There is a pin on FB125 where you select wether the DP interface is integral interface or a CP card, to select 'external interface' this pin needs to be at logic level 1.
Paul
PLucas said:
Werner
Paul
I know but the CP 342-5 is excluded and does not work with FB125. (It is somewhere on the Siemens site, if I find it again I will post the link)
Ah, makes sense now why you were asking what you were asking!
Sorry for the misunderstanding
Paul
Yep, found it. It didn't take much digging. :rolleyes:
Does that mean that SFC51 cannot be used with a CP342-5 either? I ask this because SFC51 is used within FB125. I couldn't find any information about this on Siemens site
You can get quite a bit of diagnostics information using SFC51, maybe you can use this.
Paul
Werner, do you by any chance use WinCC Flex as your HMI ?
In WinCC Flex there is a "Report System Error" functionality. This should give the HMI as detailed diagnostics as STEP7 can do. I take that you then get diagnostics for CP342-5 too.
I havent used it myself, but within this month a Siemens guy shall walk me through the usage.
Application Area of FB125 and FC125
FB125 and FC125 can be used in the following integral and external DP interfaces:
  • CPU 313C-2 DP
  • CPU 314C-2 DP
  • CPU 315-2 DP (from 6ES7 315-2AF02-0AB0)
  • CPU 315-2 DP (only 6ES7 315-2AF01-0AB0):
    • FC125 not usable
    • FB125 without detection of faulty slaves by Start/RESET
  • CPU 316-2 DP
  • CPU 317-2 DP
  • CPU 317-2 PN/DP
  • CPU 318-2 DP
  • C7-626 DP (from 6ES7 626-2AG01-0AE3)
  • C7-633 DP and C7-634 DP
  • SINUMERIK 840D with integrated CPU315-2 DP (6ES7 315-2AF01-0AB0):
    • FC125 not usable
  • SINUMERIK 840DI with integrated CPU315-2 DP (6ES7 315-2AF03-0AB0)
  • CPU 41x-2/3/4 DP
  • CP 443-5
  • IM 467 and IM 467 FO
  • WIN AC
  • WIN LC
  • Not for CP 342-5
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,853
Hi Ali, I'm setting up comms between DeltaV as master and S7300 cpu315-2 as slave. I have already comms using 1 cp342-5 bet this not...
2,423
Dear All, I try connect CP342-4 to remote ı/o Conection look like ok. But i cant find I/O address. you can find my configuration on picture...
2,505
I want to configure s7314ifm plc with cp module cp342-5. And after that I have to communicate cp342-5 with a vfd through profibus dp cb15. I don't...
2,369
Hello All, Just want to pick your brains a minute as mine is now dead :) I have a Siemens 315 PLC and I have a ABB drive (ACQ810) on Profibus...
5,224
