Cp343-1
lendyck
Feb 2006
Cambridge, Ontario
59
How can I connect a PG/PC using a regular NIC to an S7 318 processor via a CP343-1?
Some notes:
  • Simatic Manager Step 7 V5.3 SP2
  • Simatic Industrial Ethernet (ISO) is listed in my NIC protocol list
  • No ethernet interface device is listed in the Set PG/PC Interface utility
Thanks.
Len
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
333
I've been called to a site to assist with an ASi fault. The line has been down for a couple of weeks following a failure of the ASi power supply...
1,330
I have an S7-300 and an HMI. The HMI is the only device that talks over Profinet through the CP343-1 module. It's run fine for a couple of years...
517
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,734
I can not see the CPU s7-300 i only see the cp343 as photo the interface is through tcp/ip how can I upload the station via the cp343 module ???
1,014
