cp343-2 addressing
seee
Dec 2010
singapor
112
hello.
i start reading cp343-2 manual and i don't understand something as below:
In the below picture (from cp343-2 manual page 41) a 2i/20 module with address 3 has been mentioned as an example.
Bit 0 and 1 from input byte 1 and bit 2 and 3 from output byte 1
have been used. my question is why bit 0 and 1 from output byte 1 has not been used instead of bit 0 and 1?
I mean that i can use for example i300.0 and i300.1 as input
and q 300.0 and q300.1 as output. Am i right?
best regards.
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
330
I've been called to a site to assist with an ASi fault. The line has been down for a couple of weeks following a failure of the ASi power supply...
1,328
I have an S7-300 and an HMI. The HMI is the only device that talks over Profinet through the CP343-1 module. It's run fine for a couple of years...
515
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,732
I can not see the CPU s7-300 i only see the cp343 as photo the interface is through tcp/ip how can I upload the station via the cp343 module ???
1,012
