CP5511 problem...
HansAndersen
Sep 2006
Hamburg
132
I can not have the plc communicated with PG.
I have attached both network diagnostic and hardware.What may the reason of this problem.
"Tamam" ? Turkish or arabic ?
Problem likely to be exactly what the pop-up tells you - have you autodetected the network ? if not try it , sounds like the network parameters don't match the card settings .
Have you tried disconnecting the other devices on the network and connecting your pc directly to the port on the pc? The other devices/communications cable could be hosing up the communications.
The it is assumed that the BF light would be illuminated if it is that desperate . One also assumes that the system is running , though knowing the way people love to give the story bit by bit just to keep us interested , who knows ?
Hello everybody I have the same problem that this thread Error 0x0316 http://http://www.plctalk.net/qanda/showthread.php?t=13603&highlight=cp5511...
2,349
I try to communicate with CPU314 using CP5511 PC-Card. PG that is Asus A2510SB notebook (I hope my Ricoch CardBus controller is also 16bit) Bus...
2,527
Everytime I install the drivers for a Siemens CP5511 PCMCIA card, it assigns an Interrupt Request (IRQ) value from Windows of 19. As the only...
2,575
hi, i have four s7200 connected ppi, somme thing hapened, it's not possible to acceess two of my plc throuth the cp5511 mpode mpi, it found the...
1,387
Hi, I'm working with following settings: CPU 319-3 PN/DP CP5511/CP5512 WindowXP professional Siemens S7 V5.4 It was working all fine until I...
5,162
