CP5511 + XP SP2 problem
prpol
Jul 2005
3city
I try to communicate with CPU314 using CP5511 PC-Card.
PG that is Asus A2510SB notebook (I hope my Ricoch CardBus controller is also 16bit)
Bus nodes Diagnostics in Set PG/PC Interface is succesfull
also when I view Accessible Nodes I can see CPU as 'MPI = 2'.
However when uploading, downloading I get error: 'Online: No resources available in the driver.'.
Here is what Help is saying on this:
'Help on Message 33:16644
Description of Error:
The interface is overloaded.
To Correct or Avoid Error:
Ease the load on the system by, for example, closing programs or windows which are currently accessing the network.'
What can I do ??
thank you in advance
Hi PrPol,
I've have problems with several notebooks of the last generation, newer than two years. You should check the card in an older notebook. I'd to buy two new CP5512 because It is Cardbus (32-bits) and works fine with new notebooks.
Sincerely,
Kelkoon
Everytime I install the drivers for a Siemens CP5511 PCMCIA card, it assigns an Interrupt Request (IRQ) value from Windows of 19. As the only...
2,577
Hello everybody I have the same problem that this thread Error 0x0316 http://http://www.plctalk.net/qanda/showthread.php?t=13603&highlight=cp5511...
2,353
hi, i have four s7200 connected ppi, somme thing hapened, it's not possible to acceess two of my plc throuth the cp5511 mpode mpi, it found the...
1,389
Hi, I'm working with following settings: CPU 319-3 PN/DP CP5511/CP5512 WindowXP professional Siemens S7 V5.4 It was working all fine until I...
5,172
I can not have the plc communicated with PG. I have attached both network diagnostic and hardware.What may the reason of this problem.
1,599
