CPT Instruction
roxusa
Nov 2008
NJ
994
What is the symbol for divide used in a CPT Instruction
Expressions - The expression is zero or more lines, with up to 28 characters per line, up to 255 characters. Instructions that can be used in the Expression include: +, -, *, l (DIV), SQR, - (NEG), NOT, XOR, OR, AND, TOD, FRD, LN, TAN, ABS, DEG, RAD, SIN, COS, ATN, ASN, ACS, LOG, and ** (XPY). The execution of a CPT instruction is longer than a single arithmetic operation and uses more instruction words.
l (DIV) I cant make out what this is, Thanks
Maybe what I should be asking is how to find the average of a group of integers.
I was going to use a CPT
CPT would do for LAD programming; FBD (Function Block Diagram) and ST (Structured Text) languages support the MAVE (Moving Average) instruction.
Roxusa, what type processor are you using? The Logix based processors have an average (AVE) instruction.
Watch out for overflows with adding a bunch of integers together. The highest value you can have for your sum is 32767. If your sum exceeds that, you'll need a different solution.
edit to add:
Didn't realize the thread was quite that old...
Hi all. Never really noticed, but I started double checking operands in the CPT instruction. I found if I have the expression N7[37,1] - N7[35,1]...
136
I have ran into something I have not seen before and wondering if any one had any ideas. The logic I'm currently troubleshooting is using a...
1,672
Needing help with this, keep getting an error...
16
4,973
Hey Everyone I was wanting to get some advise on the math below on this expression for a SCP instruction...
17
5,273
I am trying to add 15 items together using a cpt instruction in logix5000. All of the items are in the same array is there a way i can type in the...
2,241
