CPU Battery Monitoring
Ezhil.k
Mar 2022
INDIA
Is it Possible to Monitor PLC CPU Battery Voltage Level through Special Register in Mitsubishi QCPU other than when the Battery is Already Low????
Registers for QCPU:
• [SM51] Battery low latch
Turn ON when the voltage of battery reduces to less than 2.5[V].
Remains ON even if the condition is restored to normal thereafter.
• [SM52] Battery low
Turn OFF when the voltage of external battery returns to normal.
• [SM58] Battery low warning latch
Turn ON when the voltage of battery reduces to less than 2.7[V].
• [SM59] Battery low warning
Regards
Daniel
There is no battery voltage level detection in system registers. There are a couple of system registers which provide a bit more info on the battery's condition.
Hey everyone, I apologize if this question has been answered previously. I need to replace the battery in SIMATIC S7-200 (CPU 224...
4,807
Good Morning , How do you replace the battery on a SLC 500 CPU without loosing the program , since you need to remove the CPU , and the...
12,175
I have a 1756-L63 RevB CPU and the manual said to use the 1756-BA2 battery. My sales rep said I can use the 1756-BA1 as well. Can anyone confirm...
3,062
HI, i want to know that, why EPROM & BATTERY are required in s7-400 cpu's. pls tell in detail individual function if power goes OFF.
2,259
