CPU-E light
sarnekat
Jan 2008
Telford
Can anybody help?
I am currently trying to solve a problem on a FX - 48MT plc. The problem is that the machine starts ok then half way into the cycle it stops and the CPU - E LED lights up and i have to reset the plc to get the machine to start. I changed the battery but it still did the same. I then swapped the plc for a good one and it did the same thing at the same time in the machine cycle. I use GXDEV can anybody help me what to look for?
Check diagnostic registers
Use GX-Developer to monitor D8004. That will give you a 4 digit code that is the error code.
From there I would go to www.meau.com and download manual JY992D48301 and look at Chapter 6. It will give all the different error codes and their meanings. If you have a problem deciphering what you see, post it here and I will try and help.
CPU-E almost never indicates a hardware problem. Some command in your program is working on data which it can't understand. The fact that the error switched PLCs confirms it's a program problem, not hardware. Check the D8004 address and the manual as indicated by SteinCollector.
Hello all, I'm running an SLC 5/03 CPU connected to a laptop via DH485 for programming which is working correctly (CPU light is on), however the...
2,751
I'm new to these boards and was wondering if someone can shed some light on my problem, Started up our Jensen cleaning machine and only half of it...
6,683
Hello !!! i m using S7-1200 CPU 1214C | 6ES7214-1AE30-0XB0 |. The problem i m encountering is that, the CPU's error light is continuously blinking...
15,346
New to this forum so please excuse lack of familiarity. We just purchased a Highlight Stretch Wrap machine (Synergy2 model) that uses an Allen...
14,082
I have a SLK150 that came out of a old machine we had here. I powered it up and the DC and CPU Fault lights are on. I went out and got a cable...
1,591
