AB SLC 5/01 CPU Fault light blinking
JAFA22
May 2012
Florida
I'm new to these boards and was wondering if someone can shed some light on my problem, Started up our Jensen cleaning machine and only half of it comes on, won't go into manual mode, the CPU fault light is blinking and we get signal to input side of the boards, but no lights or nothing to the output side. We have checked the battery. And i have even truest clearing the memory by jumping # 14 and #28 pin for 60 sec's w/battery disconnected. Any help would be appreciated, have called jensen and no help, cant find a local company to even come look at it, been down for 4 days .
Welcome to the forum!
Normally with Fault light blinking = no program in the PLC. Do you have a backup copy of the program either on a floppy or hard drive? Do you have a printout of the PLC program? If you have a printout but no backup copy perhaps someone here could generate a copy you could load back into the PLC. Do you have the programming software and 1747-PIC module? Answers to these questions are necessary to get you back up and running. It's also possible someone down in Florida is near you, maybe they can help. By the way you probably should post in the regular forum, more will notice it there.
Here's a link to a manual:
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1747-um009_-en-p.pdf
And a different version with more processors:
http://www.jsec-tw.com/rockwell/1747-um011e-en-p.pdf
hello at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller. I'm...
3,022
Hello everyone, I got called down to a plant to service a powdered metal press. It has an SLC 500 5/02 CPU that was faulted for the code 0002h...
1,807
Hi, New guy here. We have older Allen Bradley SLC 150s in our six Automated mini-load supply units. One unit tripped a CPU fault, and will not...
5,139
Hi, I have a CPU Fault on my AB SLC500, although i can clear the fault, but when i do a test run, the fault came back. I'm not a PLC guy, and i...
2,040
Hello everyone! I'm new to this forum, I'm hoping someone may help me out with some SLC 500 problems I have... A client has two similar machines...
8,337
