wongblack Member W Join Date Oct 2013 Location Kuala Lumpur Posts 2 Oct 28, 2013 #1 Hi, I have a CPU Fault on my AB SLC500, although i can clear the fault, but when i do a test run, the fault came back. I'm not a PLC guy, and i don't know what to do next, please help, Thanks Last edited: Oct 28, 2013
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Oct 28, 2013 #2 See pictures for a couple of possibilities. Double check grounding and make sure you have surge protection on all inductive loads. Can you tell us which SLC you have SLC5/01,02,03,04,05? Last edited: Oct 28, 2013
wongblack Member OP W Join Date Oct 2013 Location Kuala Lumpur Posts 2 Oct 28, 2013 #3 Hi Mickey, ok, i will check the grounding, meanwhile can you guide me how to reload or re-compile and reload the program. By the way, How do i detemine which SLC in have? Sorry for the question, as i am completely newbie in PLCs.
Donnchadh Lifetime Supporting Member D Join Date Jun 2002 Location Ireland Posts 1,004 Oct 28, 2013 #4 Hi Post the code if you can here if not send me a pm and I will look at for you. I am on a day off today ( bank holiday in Ireland ) Donnchadh
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Oct 28, 2013 #5 meanwhile can you guide me how to reload or re-compile and reload the program. Click to expand... Open your program file and save it. Then Get connected to your SLC with RSlinx. Start RSLogix500, open your program file and download the program to your SLC, see picture.
