AB SLC 500 CPU Fault
wongblack
Oct 2013
Kuala Lumpur
Hi, I have a CPU Fault on my AB SLC500, although i can clear the fault, but when i do a test run, the fault came back.
I'm not a PLC guy, and i don't know what to do next, please help, Thanks
See pictures for a couple of possibilities.
Double check grounding and make sure you have surge protection on all inductive loads.
Can you tell us which SLC you have SLC5/01,02,03,04,05?
Hi Mickey,
ok, i will check the grounding, meanwhile can you guide me how to reload or re-compile and reload the program.
By the way, How do i detemine which SLC in have?
Sorry for the question, as i am completely newbie in PLCs.
Hi
Post the code if you can here if not send me a pm and I will look at for you.
I am on a day off today ( bank holiday in Ireland )
Donnchadh
Open your program file and save it. Then Get connected to your SLC with RSlinx.
Start RSLogix500, open your program file and download the program to your SLC, see picture.
I used up my last new Allen-Bradley SLC 5/04 controller. Does anyone have info on a good reliable place to get a new one for a decent price, or...
543
hello at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller. I'm...
3,046
Hello everyone, I got called down to a plant to service a powdered metal press. It has an SLC 500 5/02 CPU that was faulted for the code 0002h...
1,836
I recently inherited some 5/04 CPUs and a single 5/02 CPU that I need to pull the programs from. The 5/04 CPUs didn't pose any problems. I...
3,109
Hello, first of all, I want to say thanks to everyone who is seeing this post. I have a problem with an SLC 500 5/05 processor. I need to download...
2,832
