CPU Fault Light on SCL150??
Sep 2008
Montclair, Calif
I have a SLK150 that came out of a old machine we had here.
I powered it up and the DC and CPU Fault lights are on. I went out and got a cable off of ebay and is using PCIS Ver 3.1.
My laptop OS is XP. when I hook it up and try to connect it tells me to check the cable connection. I've tried different things. I've put a null modem on the cable and it still have no connection. Any incite on this.
Read this http://www.plctalk.net/qanda/showthread.php?t=40829&highlight=dosbox
By the way... did you get it from me? does the cable have a converter on the end? if not then you have a 50-50 shot of it working, tell them you want your money back.
If you did get it from me, read the above thread, if you have any issues you can send me an email and I can help... even if you got it from someone else you can send me a PM and I will still help, but read the thread that I have linked... as you will need dosbox if you plan on using WinXP
Mark
I'm new to these boards and was wondering if someone can shed some light on my problem, Started up our Jensen cleaning machine and only half of it...
6,683
New to this forum so please excuse lack of familiarity. We just purchased a Highlight Stretch Wrap machine (Synergy2 model) that uses an Allen...
14,082
hello at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller. I'm...
3,025
Hello everyone, I got called down to a plant to service a powdered metal press. It has an SLC 500 5/02 CPU that was faulted for the code 0002h...
1,815
Hello intelligent people, I hope you guys can help me I currently have a problem with a telemecanique TSX 17 plc The plc was cut off power supply...
2,813
