CPU Status Show in Wincc Flexible 2008
faisal rasool
Oct 2015
pakistan
60
Hi Everyone,
I want to know how i show the cpu status in wincc flexible runtime. i am using the cpu 325-2dp with profibus network.
when anyone faults occurs in cpu like SF,BF i want to show these faults in wincc flexible.thanks
Thanks Lare for reply.i used this program but in this program only one LED is show at time may be i do not understand properly please guide me how i show complete CPU LED at time.thanks
haven't used it.
But how I understand it, you need to ask every led status with different call of FC112s with different parameters and Calls need to be on different program cycle.
You maybe need to also set / reset bits on program, that you can read several led status (set, if led is on and reset if led is off later,, when you asked status.)...
or only update led status to HMI, when you have succesfulle readed it from CPU.
Thanks Lare for Reply.i ready call FC112 server time.it work properly for SF fault LED,Run LED,but i need BF fault LED,when i set for bus Led W#16#11,W#16#12 its always LED Bit ON.Please tell me how i Use it properly.I am new with PLC, so Some basic Thinks i do not Know.thanks
Good afternoon, I have a Simatic S5 / S5-135U with three CPU 928B. The PLC is not operating due to a BASP error. On two of the CPU boards only...
1,059
Hello everyone, I have 8xS71200 cpu fitted profinet with Wincc RT on pc station .I use tia portla v13 sp1 and i want to check and show current...
9,566
Hi All. I'm creating several diagnostic screens for the maintenance personnel, displaying the I/O status. Do you know if it's possible to get...
3,708
Hi, does anyone knows what is the problem on an S7-400 cpu in case all the leds are constantly on (not blinking, I think in this case it that...
7,219
Hi all. Pls help me how can i check error of CPU 1769 compactlogix, I want to use this signal to sent to second PLC. and i also have to check...
1,870
