CPU313C analog input
souidi
Feb 2010
casa
20
hello i have 6ES7 313-5BF03-0AB0 and i need to make a smal regulation programme
i have PT100 3 wires, to make it in inpute
and output for a Fan 3 wires
:oops: please any help
You probably already got the documentation on your pc.
Click START/SIMATIC/Documentation/English/Step7-PID control.
You will find the PID control blocks in the Standard Library.
Highlight the FB and click F1 to view help.
K
You have to specify your problem to get help. Show us what you have already made, and point out what does not work.
Do you understand the block diagram on page 3-4 in the document I mentioned earlier?
K
Here you can see FB58 active in a CFC with PLCSIM. The output from the controller is directly connected to the input. So my fake 'process' reacts spontanously, but you can see the parameters in the controller instance DB220 and that the controller works and reacts on setpoint changes. Note that the controller must be called from an interrupt OB (here: OB35)
Hi ! I am new to Siemens S7300 (313C CPU) PLC and I cannot find the documentation related to analog inputs connecting diagrams. I have a couple...
8,949
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,706
how i configure mpi communication between etop20c HMI and 313c CPU
1,198
I have cpu313c but in cpu I have no conter,DI8*DC24V,AI5/AO2*12bit,DI16/DO16*DC24V with firmware v2.0.8.By the way I also have done hardware...
1,823
I am using a Siemens CPU313C-2DP to communicate to a network of Control Techniques UnidriveSP drives by way of a SM-Profibus module (new...
2,481
