CPU313C analog input
Then you will have to call fb58 in ob35, assign an instance-db and put in the relevant parameters. Give the instance a symbilic name, f.ex. "CTRL1". If you copy the output to the input ( L "CTRL1".LMN / T "CTRL1".PV_IN ) and the parameters from the picture, you will have a test system that plays. Play with it and try to find out what happens when you alter the different parameters.
Hi ! I am new to Siemens S7300 (313C CPU) PLC and I cannot find the documentation related to analog inputs connecting diagrams. I have a couple...
8,950
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,706
how i configure mpi communication between etop20c HMI and 313c CPU
1,199
I have cpu313c but in cpu I have no conter,DI8*DC24V,AI5/AO2*12bit,DI16/DO16*DC24V with firmware v2.0.8.By the way I also have done hardware...
1,824
I am using a Siemens CPU313C-2DP to communicate to a network of Control Techniques UnidriveSP drives by way of a SM-Profibus module (new...
2,483
