Cpu314c-2dp
AFAIK the counter inputs of the CPU314-2DP are 24Vdc. This means that anything between about 16V and 30V will be regarded as a 1-level and anything between about 0V and 8V will be regarded as a 0-level. So yes, you may connect a 5V encoder to the counter inputs of a CPU314-2DP, but it won't do you any good.
Regards,
Regards,
Mant thanks Jvdcande
Hi There,
You could (obviously) add a counter card, eg on profibus DP the ET200S cards i think are the most cost effective. www.***********.com.au have them ex stock
I am receiving the following error message on the Simatic OP17 $545 DB 32b 41 3 not avail. Before the restart that this HMI always does...
20
6,235
Hi i have Cpu314c-2dp in hardware. i want to monitor tags in wincc 6.2 with profibus interface. but in netpro when i want to insert connection...
1,179
Hello, guys! I have something wrong with my CPU314C-2DP. The situation is: 1. After 30 min working-time all CPU LEDs became fast-blinking. 2. I...
1,327
how should i network 20 s7's? i was going to use some mpi-lan converters like these. http://www.process-informatik.de/produkte/s7-lan&lang=en_ is...
1,890
Hi friends, I have 4 cpu (cpu314c-2dp) conneted to FOXBORO through FBM223 Module FOXBORO is Master ( 0 ) 4 cpus are DP salve ( 50,60,70and 80)...
2,106
