Cpu315-2 pn/dp fault
jairus
Aug 2010
Busay Cebu City
47
good day everyone.
right now i troubleshoot a STACKER MACHINE. the fault in the PLC CPU315-2 pn/dp is BF1 and SM fault. I check all the profibus cable and i found no problem. So i make it online in step 7. I uploaded the program and check the hardware configuration, then online. I scratched my head because in the actual field there are 2 Interface modules and 6 phoenix profibus modules and 15 micromasters 440 inverters link to profibus. The uploaded hardware configurations in the profibus show only 1 interface module and the 6 phoenix profibus modules, and all the micromaster 440 are all missing. I wonder what happen, why the plc hardware configuration in the plc program did match the actual field, in fact the machine was running normal on the other day. Is there is any possibility that the plc program was corrupted? need your help on this. thank you in advance.
a corrupted PLC program is a very rare fault
what is the age of this machine -
i would still suspect the Profibus connections
BF (Bus Fault)
Thank you gentlemen... I found it in hardware the diagnostic. when i uploaded the program,the micromaster 440 are all missing in the hardware configuration, maybe because my PG not package with Drive ES/simotion software, which this is the warning when i uploaded the program. but even though it missing in the hardware config. it shows the node address in the hardware diagnostic... i just search that node address and it found to be an inverter and set it parameters, and everything is back to normal operation. Thank you for all your support... God bless...
I want to realize the communication S7 and pc by cable profibus or mpi I want to know the steps to that allows me to do it
1,271
Hello , I have the classical configuration of CPU315-2DP + 5 * ET200 , just long time did not work on this configuration , the switch of Profibus...
2,629
Dear Sirs, I had a problem with CP 343-1 with CPU315-2DP.I had newly add the CP343-1 Ethernet module to the hardware to allow me to access this...
2,635
Hello Can any body help me for communicating Deltav and PLC(Cpu 315-2DP)without cp342. How am I doing this configuration in PLC. Please help me.:hmmm:
1,063
I have never installed a brand new CPU before. But, I need to take an existing project from a CPU315 and put it in a CPU319 because we are...
3,115
