Crimson 3.0 and SetNetConfig
robinsheehy
Jun 2010
Mackay
Gday,
I am programming a Redlion G306 and am using the latest build of Crimson 3.0 (222) and have hit a bit of an issue with SetNetConfig(). I have been using this on the G303 unit using Crimson 2.0 to allow the setting of the IP details from the UI without any issues. In Crimson 3.0 I get a "Unkown function 'SetNetConfig'" error when I Control+T the code. This function is listed in the rm.pdf that comes with Crimson 3.0, but is not listed in the list of functions within Crimson 3.0, does anybody happen to know if there is a special trick needed to get this function? Other than this Crimson 3.0 has been great.
Robin Sheehy
In Crimson 3.0, you can drag and drop a (properly formatted) tag onto the field for the IP address ,etc. This eliminates the need to use that function.
I'm trying to write a program that ties in with the GUI to allow users to change the network configuration of the Red Lion device on site. The...
6,296
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
128
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
262
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
116
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
101
