Crimson 3.0 - passing page label
hoy7t
Mar 2012
SC
83
Is it possible to:
Put a title block on a Master Screen.
so that the title block can display page.label for the destination page. I am trying to do this in the Master page and not in each page.
thank you.
Is it possible to:
thank you.
Here is how I do it.
Create an Internal String Tag named PageName.
Use that Tag on the Master Page where you want to show the Title.
In the On Select Action of *each* Page that uses the Master Page, type this instruction PageName = "Overview Page" (whatever you want the name to be).
There are ways to make it more fancy, but this is the down and dirty way to do this.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
147
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
289
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
127
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
105
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
97
