Crimson 3.0 Triggered Snapshot Logging
Radan77
Dec 2013
Nottingham
I'm looking for some guidance on how to set up the Triggered snapshot logging feature.
I want to take a snapshot log of 6 tags at the end of a test procedure, and then be able to view the logs and transfer them to a USB thumb drive.
I have set up a log under the Data logger pane and configured it to "Triggered Snapshot".
Update rate: 1 sec
Each file holds: 24 samples
Retain at most: 200 files
No comments or signatures and no batch logging.
I have also created a page with the File Viewer primitive so I can see the logs that are created.
The problem I have is when the log is triggered nothing seems to be happening, nothing appears in the file viewer and if I insert a USB drive nothing gets transferred on to it.
Any help is much appreciated.
Dan.
quick check:
Datalogger (main tab) 'Enable Batch Logging' is disabled? otherwise crimson will put the logs in a different file path.
Datalog name is DOS filename compatible (<= 8 characters, no punctuation, etc) ?
Tags are in the 'contents' tab of the correct datalog?
Tags are legitimate and contain data?
Tags are not security protected?
Tags access is not 'write-only'?
CF card is installed?
CF card has a subfolder named \LOGS\?
Update Type = Triggered Snapshot?:
LogEnable = true?
LogTrigger = transition to true when commanded to log data?
Set Log Trigger ON (in a script or similar). When logging is done, reset LogTrigger. I do this with a time delayed trigger. 2-3 seconds after LogTrigger is enabled, the trigger resets itself.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
253
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
109
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
98
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
92
