Crimson 3 / 3.1 alternative security manager
BryanG
Feb 2005
Manchester
1,987
Rather than reinvent the wheel by doing something myself I wondered if anyone has an alternative to the standard Crimson user/security system. Problems with the standard one are: not being able to change things runtime, and only being able to modify passwords for your own, or everyone makes things difficult. I at least need to be able to limit the passwords that someone can change to users lower in the hierarchy.
I don't know if this is helpful to you, but I stopped using passwords all together and started installing badge scanners instead. The badge scanner is read directly by the PLC and security level is coded within.
Soon I hope to graduate to a centralized server for the badge database but, until then, I simply have to keep all the machines updated one-by-one.
Steve
Hi Steve
Thanks for the idea. Probably wouldn't work here because the machines are mobile and the crews operating them change fairly often, it would be a nightmare of lost/forgotten badges. They always wear gloves to protect them from the chemicals they are using, so fingerprint is out of the question. This is my first project with Crimson and I am a little disappointed in the security options. I am hoping there is something that can be done with SQL and some programming.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
230
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
107
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
92
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
91
