Crimson 3 Emulator and OPCWorx
jhoneck
Mar 2013
Austin, TX
Can the Crimson 3 Emulator be used "stand-alone" connected to OPCWorx to connect to a SQL database created by my existing SCADA software? I would like to be able to use Crimson as a virtual HMI by virtue of its web server. But, the Crimson 3 manual states that Emulator is limited to 15 minutes if connect to a network port.
I have run into the 15 min limit in the past so unlikely to be much value past the designed intent: verifying the design before actual hardware is procured. Have you looked at Ignition from Inductive Automation? They make a great product for the PC that interfaces easily with SQL databases.
I think Ignition is still pretty expensive for what I want to do. I just found out that OPTO 22 can do this by just buying their OPC software for $400 plus they seem to link with Ipads etc. The Red Lion solution would involve buying a Data Station and their OPC software for a total of $2000 plus. Ignition looks to be much more expensive too. Thanks for your response.
Jeff
Sorry for the delay in seeing this thread, but wanted to clarify that the OPCWorx software will not work without having real hardware.
Jeremy
Hello Kind Folks, On my Red Lion Crimson, the "Send to Emulator" box is greyed out, and thus I'm unable to run the emulator. Has anyone run...
3,462
Hi Experts! I am trying to get a Redlion Crimson 3.0 HMI to talk to a Rockwell Emulator. I imagine I'll have to use OPC DA. Has anyone done this...
1,177
Using a Raw serial driver in Crimson 3.0 I'm trying to test some code. I've written some code to transmit so ascii characters with PortPrint() and...
1,091
Hi there, I'm very new to all this and I would like to ask for a bit of advice. If possible, can someone please point me in the right direction...
1,177
Hi, Has anybody found a way to make RedLion Crimson 3.0 Emulator "talk" to Rockwell Studio 5000 Emulate (within the same PC, running Windows 7...
1,954
