Crimson 3 Translator
Snitz50
May 2014
Okemos, Mi
Crimson 3 states that my database is un-translated when I hit F9 to start it and that there may be problems if I do not translated it.
What is this about?
You have a program that wasn't translated. You will see a program that is yellow instead of green.
Translation Question
I am new to Crimson but not to programming. When I tried to use the emulator the first thing it responded with was a warning that I needed to translate the program. I looked through the manual and the only mention of translation was for different languages ie. French, German etc. Why would I need to translate to another language. I thought at first that it meant translate like compile but I could not find a translate/compile references.
Also, I see nothing in yellow except for the highlights on the areas I am looking at ie. Commutations, Data Tags etc.
Thanks for any help.[FONT=&quot][/FONT]
For any programs that show red in the navigation pane, place your cursor in the Source pane and either hit the Translate button in the tool bar or hit <Ctrl>T. It's a good way to check syntax.
Note: you will get this when you try to send to the emulator despite the fact the it doesn't run programs.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
150
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
301
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
128
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
117
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
97
