Crimson datalogging & arrays
hoy7t
Mar 2012
SC
83
Using Red Lion PTV:
I want to log various elements of an array.
when i drag an array tag into the datalog contents box, it enters the array with index [0]. i cannot edit it.
Can i datalog elements of an array?
and can i use data tag definitions in an array such as tagname.min, tagname.max, tagname.sp anywhere"/.
thank you
Using Red Lion PTV:
thank you
The proper way to reference elements of an array would be to type in the name into the databox. For example you would have to set the source to general and type Array1[0] or Array[1].
You can use this reference Array1[0].min or Array1[0].max
Jeremy
Great. thanks.
i would like to make these items available for data entry. but crimson wants them to be display only.
user manual mentions "User Defined" setting for data limits. but the presentation looks different and does not offer this option.
advice?
You can dynamically set the min and max values but not with the .min and .max, those are read only. You would create two additional tags and drag them into the min and max values for the datatag you want to control.
Jeremy
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
145
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
279
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
126
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
105
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
96
