Crimson flags and triggers
hoy7t
Mar 2012
SC
83
Red Lion Crimson:
I am using a flag tag. I want to use a trigger.
I set mode = active on. i put logic in the action.
Trigger logic does not execute.
Any help?
Could you give more details on what you programmed with the trigger? You can also post your database.
i found the problem.
it appears that trigger action logic may not run to completion before it is preempted.
i changed logic so that timing did not matter. problem disappeared.
thank you.
Is it possible to change the status of a flag via email. ie: I have a FLAG (simple ON or OFF, deafult OFF) [currently my flags status is...
3,146
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
130
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
265
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
119
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
101
