Crimson Rotation Animation
Okie
Here is an example of how I do my animation. It is basically an infinite loop running in the background. Basically I just put images where I want and trigger their visibility.
Not sure if it is the simpler your looking for but it does work. I start the loop off of Startup.
Drive one of the exploding trucks
zipped cd3 file for emulator.
Yep, I think I got animation down good enough now...
I would like to know if it's possible to have images in the animated image object with a transparent color instead of matching the background, and also when they are going to increase the image count to 36?
I'm having problem with the rotation of polygons about a point. I'm trying to use a polygon rotation as an indicator needle. Is there any way to...
2,676
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
149
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
298
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
128
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
107
