Crimson v3.1
ceilingwalker
Mar 2010
Phoenix, AZ
1,588
Hello all. I have a compactlogix interfaced with a RedLion HMI. I have a function in my logic that is outputting seconds of a cycle time as a DINT. I am able to see it just fine on the HMI however, it's 8,095 seconds. How can I manipulate the data so that it times-down from 0-60 only? I have the same issue with minutes......it shows 98 minutes (which is output by the PLC) but would like it to show only 0-60 minutes. I used to know how to do this but haven't touched a RedLion in quite a while. Thanks.
Limiting seconds and minutes to a range of zero to sixty implies that you're trying to convert from seconds to hours/minutes/seconds. Is that what you're trying to do?
No. For example, the PLC is feeding the HMI total cycle seconds remaining as a DINT. It is read as a total cycle seconds remaining.....such as 8,500. I am trying to manipulate the data to read that data as 0-60 seconds instead of 8,500 so this it shows only the total seconds remaining.
I'm having a hard time understanding. Is the value of 8500 in the DINT the remaining time in milliseconds? What is the difference between "total cycle seconds remaining" and "total seconds remaining"?
That's alright, I solved it by inserting a MOD instruction in the ladder and that feeds back to the RedLion. I was just trying to find a way to do it through the Crimson software is all. Thank you.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
150
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
301
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
128
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
117
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
97
