Crimson3.0 HMI file Paper Printout
gbradley
Apr 2002
Corona, Ca.
1,637
When I build something involving a PLC, I always like to make a paper printout. To save in a little booklet.
When creating an HMI program In Panelbuilder 32, I was able to create a PanelBuilder32 Application Report that showed screen lists and tags.
Is there a way to create a similar printout in Red Lion Crimson 3.0 showing the pages and Data Tags?
I often use the emulator to grab screenshots for documentation. If unable to connect to real hardware to get satisfying images with normal looking data, I will change all the tags to internal en masse and poke simulation values in them.
You can export the tags to a csv file.
Those two things are not "report ready" methods and require extra effort and time to make them look how you want. And they don't deal with page lists or tags in use per page which are some things that other HMI software can do automatically.
I don't know of any built in report options in Crimson which would do any reporting for you.
How to change Daylight saving time ON/OFF automatically in Crimson3.0&3.1/Redlion HMI How to change Daylight saving time ON/OFF automatically in...
2,187
Hi Crimson3.1 uses the GotoPage() to navigate to pages and the argument has to be a Display Page example: GotoPage(Page1); However since...
895
Is it possible to calculate the time difference between two timestamps in Redlion crimson 3.1? Thank you,
1,411
Hello, I am still learning crimson 3.1 programming and I need help on mapping the flag datatag to digital output expansion module. I am using a...
1,584
I have dozens of Red Lion G304K2- RED LION KADET HMIs. I think that they are great! I have always programmed them with Crimson 3.0 software...
1,613
