CRT or LCD Monitor
I tried to find a solution to this for one of my customers, but had no success, however I am no expert on monitor inputs. I tried getting a CRT computer monitor that had both VGA inputs and the same signal split to RGB but the S5 seemed to be missing a sync signal that the monitor needed. I also tried an RGB to VGA converter that was meant to allow old Apple MACs to work with standard screens, but again no joy. Fortunately the problem went away as they finally upgraded that part of the plant to S7s.
I did find that RGB monitors were usually repairable at my local TV repair shop, but they went bust after everyone started switching to LCD televisions.
Bryan
I too had the same problem and we also upgraded to S7. The problem is that the sync signal is too slow for a standard monitor. We found a UK supplier of rgb monitors and bought a new one!
Thanks Bryan, I tried to connect an old sony monitor and it worked, but the problem was that the display was blurred and dificult to read due to poor resolution may be.
Hello everyone! We have a computer running on Windows XP 32 bits SP3 where Simatic Net Softnet IE 2008 Lean is installed, with C++ (VC6.0 and...
1,410
Hello I searched for datasheet "manual" for this module : 6ES5 250 1AA11 ,, and I didn't find anything... Where can I find pdf for this module...
1,823
Hello I have a system contain: Siemens S5 PLC connecting to SRT Screen via this module in image below: Is there any pdf or sheet for this...
2,240
It seems that over the weekend we lost the CRT on a PanelView 1400E (Cat#2711E-T14C6 Ser.A). Has anybody used any of the LCD "drop in...
6,509
My CRT has gone out on my panelview 1400e, but all communications and controls are still functional through the function keys. Of course, for...
7,164
