Cscape ramp/soak function
Syriss
Jul 2011
new york
Alright, so the other day I finally figured out a way to create a ramp function in cscape to allow me to steadily move my analog output from 0V to 5V on my horner he-xe105.
2 Questions:
Did I go about achieving this function in an efficient way? If not, how could I improve it?
I am having a real hard time figuring out how to have it hold the final value steady for a set time period, and then ramp down slowly back to 0V. Could anyone help me accomplish this task?
Attached is a screen capture of the cscape ladder that I currently am trying to work with.
Thanks in advance for your help!
First, you will need a Latch relay (call it R1) to lock out the ADD function when AQ010 = 15950. This Latch relay R1 stays set until Reset at the end of the Down Ramp. You may can put this Latch relay R1 on a rung branch parallel with the R0003.1 output, or it could need a separate rung depending on the capabilities of Cscape. When R1 is ON, it locks out the ADD function so that it cannot add to AQ010.
Second, you need another parallel branch to the ADD instruction that does a SUBtract when R1 = ON. This SUB function should cause the reverse action of the ADD function (after the UP Ramp is done, and R1 = ON).
Third, at the end of the Down Ramp (AQ010 = 175), you need to reset R1 ONE TIME ONLY, so that the cycle can repeat, if desired.
You need a way to lock in a relay or device that says basically "UP Ramp has been finished". Without that, it will be difficult to get your logic to do the Down Ramp.
Most programming languages have a type of relay that, once turned on or SET (sometimes called LATCH), it stays on without any further inputs of any kind. It only goes off when a special RESET or UNLATCH is triggered.
If Cscape does not have a SET or LATCH or something similar, then you can create your own using an ordinary relay like this:
| Unlatch |
| AQ010 = 15950 R2 Latch |
|---+----| |----+----|/|------(R1)----|
| | R1 | |
| AQ010 = 175 Unlatch |
|--------| |------------------(R2)----|
Great news. For triggering the SET coil, you may need to use a "Greater Than or Equal" comparison instead of an EQUAL. If the value of AQ010 can get set greater than 15950, then using an EQUAL comparison could cause an error. The same logic applies for the RESET function: you may need a "Less Than or Equal" to avoid problems.
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
71
I've just started using Horner Cscape version 9.90 service pack 11. Is it normal for all the toolbars in the window to appear in a different spot...
202
I seem to be making this harder than it should be, and Its not making any sense. I simply need to move a real variable to two integer variables...
986
I am working on a program in Cscape to take a pulse input from a flow meter and output an average of the last 5 minutes of flow and total flow to...
574
I am working on a program in Cscape to calculate a flow in gpm with a pulse input. Currently, the data collection, labeled as minute counter and...
724
