Cscape Remote Alarm history Clear & Ack help
gregman900
Oct 2011
Michigan
Hello,
can anyone point me in the right direction, i cannot figure out how to write the ladder for remote clearing Cscape Alarm history, if anybody has any program with examples they would be greatly appreciated.
thanks Greg
From the help menu on CScape here is what it is says:
The history log provides an entry for each transition of an alarm state (history of Changes). The history log length is limited to 128 entries (256 entries for OCS 451/551/651 and is stored in non-volatile memory. Entries are only cleared at program download or through operator intervention. Once the log becomes filled, the least current entry is deleted when a new alarm event occurs. Noted that re-occurring alarms can quickly fill the history log. Entries contained in the history log show alarm transitions to the following alarm state:
ALM – Alarm went active
Optionally, the following alarm states can also be logged and shown if checked in the alarm configuration:
ACK – Active alarm was acknowledged by operator.
CLR – Active alarm was cleared by operator.
RTN – Alarm returned to inactive without being acknowledged.
Note that transitions from either ACK or RTN to CLR are not logged.
Why not just let the buffer fill up? You will always see the history of the last actions.
Regards,
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
105
I've just started using Horner Cscape version 9.90 service pack 11. Is it normal for all the toolbars in the window to appear in a different spot...
215
I seem to be making this harder than it should be, and Its not making any sense. I simply need to move a real variable to two integer variables...
1,013
I am working on a program in Cscape to take a pulse input from a flow meter and output an average of the last 5 minutes of flow and total flow to...
581
I am working on a program in Cscape to calculate a flow in gpm with a pulse input. Currently, the data collection, labeled as minute counter and...
743
