Mark Snodgrass
Something else you have to consider with a larger motor. The no-load current of a larger motor will be higher. For example, a 100hp motor I looked up draws 28A no-load, while an identical motor but at 125hp draws 44A at no-load. That gives you 16 less amps of available power if both are limited at the same value. That would mean the larger motor would actually not be able to provide as much power to what it is driving as the smaller one would.
You may still get yourself out of a bind, but you may be limited as to true capacity.
BCS and DScott, I'm originally from St. Pete till the navy took me away and now in NC.
