muds Member M Join Date Apr 2014 Location karachi Posts 71 Feb 21, 2016 #1 hi all, i want to control my stepper motor with my Delta dvp PLc,, how can i control pulses, steps and directions of motor though it,, thanks in advance
BITS N BYTES Lifetime Supporting Member B Join Date Jun 2005 Location Miami Beach Posts 484 Feb 22, 2016 #2 Step 1 = read the manual!!
just the cowboy Member Join Date Nov 2013 Location Pa Posts 264 Feb 22, 2016 #3 Check to see if it can Not all PLC's can do motion control, check to see if yours does. If not automation direct has a DC DL05 with pulse step output for aqround $120 us
shooter Member S Join Date Sep 2002 Location duketown Posts 2,711 Feb 22, 2016 #4 what voltage is the output of the PLC and what input has the stepper driver?
shooter Member S Join Date Sep 2002 Location duketown Posts 2,711 Feb 22, 2016 #5 what are the voltages and a PLC is not fast enough on its normal ports so you will need a special card for it.
