CX-Designer Questions
Tommycai
Aug 2011
KY
120
Does Omron's Cx-Designer Have a parameter (compared to allen bradley's?) Can I assign an HMI Button to display or assign parameters to one bit lamp?
I am trying to Make an IO Screen that Changes the Text List When a Button is pressed and have one Bit lamp for each of the 15 bits i.e. 0.00, 1.00, 2.00, 3.00, 4.00 goes all to the same bit lamp but assigned offset to change when the user presses an HMI button along with the text as well.
Hi Not Exactly as what you mentioned, but I have done that in another way.
Attached is the CX Programmer and CX Designer files.
1. Open the file & run the CX Programmer in simulator mode
2. Open the file & run the CX Designer in test mode, linking to simulator.
3. Open the PLC memory area and key in values in CIO fields
4. At the HMI test screen enter the channel number to monitor.
Regards
Regards
Thanks I will give this a try this weekend I appreciate the program.
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
268
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
143
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
216
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
194
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
152
