CX-one Step programming reset
arcomp
Jan 2016
Milnerton
I am programming a blow moulding machine with 2 stations. So far I have the sequence done with function STEP ( and SNXT). How can I jump automatically to Step 1 when I press the "Cycle Stop" button.
At the very moment when I press cycle stop the current marker in the sequence stays. So when I go to Basic Position and press cycle START all gets mixed up because the cycle is not at Step 1
Copied from an example I use the work marker for each step:
Step 1 W100.01
Step 2 W100.02
aso.
Function
RSETA [W100.00 1 15]
doesnt work. Error message "Operand out of range."
Thanks for help.
Andy
Hi, I have a 315-2 PN/DP CPU. It was programmed in Step 7 V5.5. Then a colleague programmed it in TIA Portal V13 for a test. Now I want to...
2,281
I need material for programming step 5 Plc SIEMENS?
1,596
DEAR FRIENDS, I WANT TO KNOW THAT WHAT IS THE USE OF S100 BIT IN DELTA PLC PROGRAMMING. CAN ANYBODY GIVE ME ANSWER. THANK YOU :nerves:
2,298
Good Day Experts, I have a small problem in programming which I would like to discuss. I am using an AC drive of different manufacturer with...
2,058
