CX programmer HELP! Please!
sowallace
Jun 2021
alabama
I have a 16bit PLC. The logic is a step by step process from W98.00 to W98.15. My task is to add a contact (new steps) between that logic. Im not the best PLC guy in the world so I tried to added a different W-Ch/W-bit in the logic as a step but the logic ran through the code as if I did no work. I also added all the related instructions similarly to the W98.00 throughout the logic but that didnt work. As an example, I added a attachment to sort of display where Im trying to add another step. I dont know if I need to use the Jump instruction or what. Any ideas are welcomed! Thank you for your time!
If you want to add a branch in between 2 lines -
Click on the instruction above which you want to add a row, then right click->Rung/Column Edit->Insert row
If you want to add a contact in between to contacts -
Click on the contact of before which you want the contact to be and press Ctrl+Alt+(right arrow on the keyboard)
This will push all the contact towards right and give you space to add a contact
In the hand position: Pumps 1 and 2 are controlled and alternated by the hand selector switch. When Hand position is first selected, pump 1...
3,598
I have a mac 90 on a machine which has died a death (well the screen has anyway). I have searched the threads for some idea of where to find the...
2,087
Hi ppl, I've just finished my second year studying Electronic & Computer Engineering @ Uni, in the UK. During summer, i'm involved in an...
5,777
Hi everybody, I´m wondering if somebody knows the UI3000A handheld programer, I´m interested in what it needs to work with CNC robot, also some...
271
Help please. Im new to Omron and have a machine down. I have a compare = for barcode label scan. I've attached two pics. On the Mnemonics you can...
636
