cx programmer scaling
Anu Amne
Mar 2018
Athens
Hey guys, how can i know that my scaling is right just with the simulation( without the plc or the external components). I m doing the scaling but im not sure if its right or wrong...
Change the input of your scaling instruction to an internal word. Edit the internal word and check the results of the scaling function. If it is what you predicted then the instruction is fine. The scaling instruction will be a straight linear function of the input based on the points entered.
Regards,
Hey guys, I've come across some code that is scaling an analog value in a GE 90/30 (now porting to RX3i). There's some oddity going on that I'm...
2,630
Hi, I am new with Omron PLC. I am currently having problem with SCL block function. The SCL block function takes input from analog water level...
7,793
bonjour je souhaiterais savoir si c'est possible de faire communiquer Cx-programmer ( logiciel de programmation des automates Omron ) avec...
157
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
158
I need a good website or tutorial to learn plc programming Thank you
511
