d.c. motors
micky beard
Jan 2009
10 amalfi cr. yangebub w.a.
We have a portainer crane,it has 12 d.c.motors to drive the crane in a longtitudual direction.The motor armatures are connected in parallel,with a load sharing resistor in series with each armature.The motors are supplied by a a.c. /d.c. converter.My question being how does the load share accross the motors if one takes more load i.e.due to a tight gearbox om one drive.
Thanks micky beardo_O
If one motor has more load than the others, it draws more current. The larger current produces a larger voltage drop across the load sharing resistor and hence a lower voltage on the motor. The lower motor voltage tries to make the motor run slower resulting in less load on that motor. The motor does not actually run slower since all the motors are coupled together through the wheels but the load on that motor is reduced.
If one motor has a large additional load such as a tight gearbox, that motor will probably end up freewheeling and the other motors will be driving it through its wheels and gearbox.
I have seen DC motors where the series field of motor A is connected in series with the armature of B and vis versa. Thats another way of sharing the load
Roy
Dear colleagues, hope you can help on that matter. We have a project where we need to control 3 servomotors to move a auger feeder system...
38
1,197
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
241
In a control System, I need to move 3 motors attached to roller in stages with speed of 1 to 2 RPM and the torque of motor should be 8-10 Nm...
836
I'm working on a design phase for a costumer and they've requested PM motors for all conveyor belts throughout the system. We have a gapping...
532
Hi guys, I have a problem with setting up the parameters for PowerFlex 525. So we have 4x motor connected in parallel to 1 PowerFlex, each motor...
1,121
