D100 Programing Cable (Cat 5 Looking)
W8WCA
Apr 2007
Columbus, OH
Hello all.
I have a D100CRA14 (the small d100) and a D100CPM232 RS232 converter - (for one computer to one PLC as I understand the manual)
Now I need 2 things:
1) What is the pinout of this cable?
One place here I found said pin 1 to 8 pin 2 to 7 etc
Kind of reversed ends
2) Can I use a Std 25 pin to 9 Pin RS232 adapter?
I made up a Cat 5 cable with the above wiring, and used (what I think) is a std 25 pin to 9 pin RS232 adapter.
And cannot connect to the PLC
I tried it in programing mode as the manual said and in both halt and run positions, still could not connect.
I do not recall having any issues connecting WAY back when I got this, but I did have a PC with a 25 Pin RS232 back then , and I had the stock "cat 5' looking cable
Thank You,
Charlie Alexander
For question 2, it "should" work.
Also you need an older computer with a REAL (not USB adapter) Serial port, running Windows98SE or earlier software. I prefer an old 486 desktop personally. I have emailed you a copy of the interface and cable. You should be able to connect in "RUN" or "HALT" because you can monitor in "RUN". It must be in "HALT" to write (program)the plc.
I hope that helps.
Sid
Thanks Sid:
Well I am running it from a AMD 1.6 Gig Laptop. from a RS232 9 pin port.
I run DOS6.22 on it.
I was just wondering if the RS232 converter needs power from the COmputer - many laptops cannot run some converter type RS232 deals - they do not seem to have enough power from it.
ill give a try from a Win98 desktop at home.
Or from a old 486 Laptop to home
More wil follow.
Charlie
Can I get the cable diagram as well. I have the same issue without a 25-pin serial port. I am going to try to use a 25-pin to 9-pin adapter for now. But may need to make a new cable. Any information for the cable to the D100CPM232 ver A2 would be great.
A standard 25 to 9 pin adapter should work for the computer side. Also, do a search on the forum for keyword "d100" (without the quotes).
See this thread (post 10 and 11) for the "RJ-45" connector type cable.:
http://www.plctalk.net/qanda/showthread.php?t=8115&highlight=d100
I need to make some program changes on a cutler hammer D100. I have the software I need but want to know more about it. eg what is the software...
9,059
Hi everyone, I know this is an old one but we have a d100 in our wrapper , it just stopped working. When the inputs are pressed the corresponding...
246
Good afternoon, Looking to purchase one of these RS232 - RS422/485 Adapters ASAP but not having any luck online. Even Radwell has come up empty...
1,027
Does anyone have the actual pinout of the Toshiba EX40 Plus / D100 Programming interface/connector RJ45 socket please? OR: Can anyone tell me...
4,150
Here is a link I found for some old D100 manuals, they may be applicable to the Toshiba EX20/40 series of plcs also. Please forgive me if I...
1,485
