scottmurphy
OP
- Join Date
- Oct 2004
- Posts
- 363
John Paley,
Thanks for your input there, it has given some information that I did not have.
I think this is the key to g to understand the old system. There is a great selection of bias resistors, trim pots, adjustable resistors etc.
How is this normally done, there is a Spindle RPM signal installed? This will be another key issue, as the rolls are changing in diameter depending on thickness. I was going to start with an average, and work from there.
At the moment, I am only going to do the UW end, so the RW will have the old analogue system still.
Will I be able to get the dancer to hold at 0 speed using this method?
That is exactly what they ahve said to me, it should not move, they have an idea that they can rest their coffee cups on the dancer....not possible I guess.In my experience, the operators don't like to see the dancer move while winding/unwinding. But it has to. here's why.
In the old analog systems, this can be done very smoothly and dancer movement is minimal. In the digital systems of today, the diameter range is traversed in steps. The better the diameter resolution, the smaller the diameter step, which means less dancer movement. But it still has to move to work.
In an unwinder, first you need an accurate calculation of the starting diameter. This is done differently in different systems. But it is basically line speed ref / spindle RPM
I am using the LWH series at this site http://www.novotechnik.com/linear.html to give me dancer position.The type of transmitter you use depends on your system.
