laser type analog dancer for drive trim
irondesk40
Jan 2008
nc
630
anyone have a idea on who makes a laser type analog output sensor that could be used to detect the position of fabric and trim a AC drive? Director of our group is dead set on being able to trim the fabric speed but can not have anything such as a dance assembly etc. contacting the fabric. I have searched the net, but not much luck. Anyone ever used anything like this and would share would be great.Thanks
keyence makes laser distance meters, they triangulate the beam that is coming back,
another way is to have optocoupling, like the old pdp tapemachines have with a vacuum loop.
another one is a safety curtain type.
and if needed very high precision in the 0.01 mm range i have a solution with a position sensor working optical
Be careful what laser sensor you choose. Many time of flight lasers have an update rate that would be too slow for most loop control purposes. The Triangulation lasers work well but have only a limited range, Keyence would be my choice too.
Depending on the dynamics of your system, an ulrasonic distance sensor might be a better bet.
Nick
I've had some recent positive experience with a few IFM Efector 01D100 distance sensors. Great little units and around $500 with accessories.
But I've never tried something like these in place of a dancer or loadcells.
thanks, have banner and keyence rep coming in later this week.
Now have a question i hope someone can possible help with. Originally the boss wanted this analog sensor to trim only one motor. Now he wants the system designed so that this analog sensor will trim the speed of all drives. There will be a total of 3 drives that will need to be trimmed with this one sensor. it looks like i will now have to feed this sensor into the plc and then trim the output to each drive.
Brain dead and not exactly sure how to bring in a analog signal of 4-20ma and trim the line speed a + and - percentage.
Any thoughts from anyone that may have done something like this. When i get in the office going to work at trying to get this part figured out, but just not sure how you can send a motor a analog output that is scaled in the plc to run a line speed and then if the analog sensor is in the middle then the value from the analog sensor would be 12ma. The only thing i can think of at the moment is do sometype of compare but still not quite sure how to accomplish this. Not asking to tell me how to do it, but any ideas would be appreciated that may help me get in the right direction.
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
240
Hi experts, I hope you're all having incredible days. I'd really like to utilize this sensor for a customer application, but the issue is that...
17
18,849
Good Afternoon , We have a few Datalogic Laser Sentinal Scanners . We have 2 that are pointing upward toward the ceiling . Roughly , within...
1,042
how to program a laser level sensor to a cooler tank with an AB plc
1,319
Hi everyone, I don't know much of PLCs but it happened that i need to connect Leuze AMS358i Ethernet laser measurement to Productivity 1000...
1,063
