scottmurphy
OP
- Join Date
- Oct 2004
- Posts
- 363
Unbelievable
Ok,
After getting the machine back late today, I though that I would go back to absolute basics, and try and simulate the previous system, that is, to control the axle directly off the dancer. So, all I did, was take the position of the dancer, and use that as a speed reference for the axle, no line speed reference, reel size, type of material etc.
And it worked. I ran the line up to 85m/min, and down again, the dancer moved slightly, but there was no hunting or bottoming out.
I only had a small reel, will go back tomorrow with a larger reel and see if the results are the same.
This is what really frustrated me, after all the theory, calculations and programming, and only 2 rungs did it. The problem that I have, is it is so crude, it is not funny. There is no line speed reference, no PID, just a reference directly related to the dancer position, when at preferred position, speed ref is 0, at max speed is max in direction of web, when at min, speed is max against direction of web.
So, all that is happening, is that it is like torque control, with the UW speed primarily being controlled by the pulling motor.
I haven't had a chance to put some decent thought into this method yet, I was too blinded by the fact that it worked so well. I still need to be able to match speeds with the new reel for splicing over, but this shouldn't be too bad to achieve.
I just do not like it as it defied the theory and calculations, plus it is so crude.
Ok,
