Danfoss vlt 2800 error 15
segar
Feb 2013
malaysia
HI,I HAVING PROBLEM WITH DANFOSS DRIVER VLT2800 (ALARM) ERROR 15
I CHECK IN THE MANUAL ,ITS SAID THAT SMPS FAULTY ,I DISMANTELLING THE DRIVER AND CHECK THE CAPACITOR IS HIGH VALUE 220uF/35V ,WHEN I MEASURE WITH LCR TESTER ITS SHOWING 229uf/35v there have 4psc so i replace all of the 4psc and see,the ALARM STILL APPEARS ,AND I CANNOT RESET ...... CAN ANY ONE TELL ME WHERE WILL BE THE FAULT IN THE DRIVER?
THANK YOU
15 Switch mode fault (SWITCH MODE FAULT)
It is a fault in the internal switch mode power supply, so contact Danfoss service
jera
as your reply i know that SMPS is faulty,and have to contact danfoss in he user manual stated.
but i already check in the SMPS PCB boards is only the capacitor is faulty,so i have replace the capacitor and on the driver ,but its still is same, so i have do some-more troubleshooting but i cannot find any faulty component ,so i need some one to help on this really dear friends, please .
thank you
It's a common fault, I dont think the power supply itself is faulty as they usually give-out all the right voltages, it's a problem with the thing that checks the power supply. I have had many VLT2800's fail with error 15. Poor.
Hi all, I am having a problem with 3 VLT 2800 drivers. All are showing on occasion error 16. I know that this points to short circuit on the...
2,303
Hi, I've bought a preowned Danfoss VLT 2800. When I started it for the first time it displayed ERR 7. I did try to reset to factory setting by...
1,833
Hi EveryOne! when I power up my Danfoss VLT 2807 drive it shows an Err.8 on display, further its alarm light keep blinking while its warning light...
7,571
Hello all. I am hoping someone here has installed a Danfoss VLT Midi FC 280 and connected an encoder to it. I am just trying to make sure I select...
474
Having a small problem with a new danfoss micro VLT FC51 drive I was hoping someone on here could help with. my setup: my motor speed is...
1,436
