Danfoss VLT FC51 advice on fault
liamgratton
Nov 2022
liverpool
Having a small problem with a new danfoss micro VLT FC51 drive I was hoping someone on here could help with.
my setup: my motor speed is controlled via 0-10vdc pot (with a voltage display/ indicator in parallel) connecting to the FC51.
when started at 0vdc on the pot, the drive goes into alarm (code: AL 13) and trips and it won't allow me to turn the frequency/speed up before it alarms. I reset the drive and turn the pot up anywhere above 0vdc and my motor rotates fine, and I can adjust its speed. does anyone know what is causing this?
I have measured all voltages, check motor spec and exchanged the pot but no luck. I have also adjusted the low ref point on parameter 6-14 term 53 from 0 to 0.75. which at first solved the drive tripping issue but also meant when started at 0vdc there was some creeping from the motor. now the issue has come back, and I don't want to change parameter 6-14 as there must be an underlying issue.
Any help would be great!!
Shock load or fast acelleration is a common cause check the motor drive/gearbox or what ever is free enough it could be binding or too fast aceleration.
I have the same set up on 2 other machines, so I don't think it is acceleration. Mechanically everything is fine and nothing binding/ jamming it up.
Hi Guys Took over a job where the customer has VLTmicro fc51 drives. Im installing a plc to control them so I would need a digital input from them...
2,685
Hello all. I am hoping someone here has installed a Danfoss VLT Midi FC 280 and connected an encoder to it. I am just trying to make sure I select...
464
Hello everyone, I am an engineering student who took on a project to design and build a control system for an industrial coffee roaster as my...
4,503
Hi all, Got a Danfoss FC102 VLT drive which reverts to Off mode whenever I cycle power to it. I'm controlling it over ethernet from a Control...
1,833
Hi all, I am having a problem with 3 VLT 2800 drivers. All are showing on occasion error 16. I know that this points to short circuit on the...
2,294
